somethings wrong
Old Sep 10, 2004 | 03:53 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
somethings wrong
My car is a 90 350 iroc. The trans was toast and i just had it replaced with a 700 out of an 86 305. The mechanic checked out the new trans and installed it and everything seemed fine. When i first picked it up and started driving it i was surprised because it was shifting so soft i couldnt even feel it, but somewhat disregarded it because my old trans had a shift kit in it and this doesnt. Well i get about half way home and it all starts falling apart. If you accelerate slowly from a stop it wont shift till much later then it should and if you get on the throttle a bit so that it should be shifting where it wants to anyways it shifts so soft you cant feel it. Any ideas on what he might have messed up?
EDIT: also i checked the trans fluid when i got home and it was a little bit overfilled but not by too much.
Old Sep 10, 2004 | 04:02 PM
ljnowell's Avatar
My first guess, incorrectly adjusted TV cable.
Old Sep 10, 2004 | 05:47 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
just checked it and it was adjusted fine
Old Sep 15, 2004 | 01:03 PM
ljnowell's Avatar
Well, did you figure anything out yet??
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Dyno Don
Jan 24, 2016 08:24 AM
TheTraut88
Sep 11, 2015 05:16 AM
