83 Fbody Posi interchanging
Car: 1983 Z28
Engine: 383
ok im off to the local pick apart this week to find a posi and 3.73 gears for my maro. So far i know im looking for a 26 spline unit,Does anyone know which other vehicles these came in so i might have a better chance of finding one?
Any advice on which to get and which to stay away from?
Thnx in advance!
Car: 4
Engine: 6
Transmission: 5
The only vehicles that are likely to have what you're looking for, are 10-bolt Camaro/Firebird from about 85 or 86 to 88.
Parts from S trucks, G bodies, and some B bodies, will interchange. However these vehicles usually either had no posi, often had 2-series gears, and (in the case of the trucks), if they did have posi, it was the Gov-Lock. You don't want a Gov-Lock under any circumstances. The S trucks do however have good gears in them alot of the time; esp. 4WD ones. MC SSs also had 3.73s almost exclusively, but rarely had posi.
Car: 1983 Z28
Engine: 383
Woohoo found posi,not govloc.$46cdn at local yunk yard in a caprice.If ya look under the trunk lid where the put the options tag look for a G80 code.
KO1
16
Oct 15, 2015 05:00 PM
