Identifying carrier help please
Old Sep 13, 2004 | 12:49 PM
84camaroBC's Avatar
Car: 1984 Camaro F41
Engine: LG4
Transmission: 700-R4
Okay, thanks for helping me out.
I got a 28-sp posi carrier super cheap, but I don't know what it came out of or what gears it used to have.
How do you tell what series it is
Oh, it looks like this if it helps:
Old Sep 13, 2004 | 01:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's an Auburn. Looks like one of the ones that used to come stock in LT1 cars. It's probably 3-series, but I can't really tell from the pic. It probably came from somebody that got it from SLP back when they were selling those as take-outs, like they did the Torsens more recently.
Turn it over so we can see the other side of the ring gear flange; and take a pic, and leave it larger (like 480x320 or something) so we can see how "tall" that flange is, from the carrier bearing bore.
Old Sep 13, 2004 | 02:17 PM
84camaroBC's Avatar
Engine: LG4
Hey thanks. I'm at work now so I can't get a pic, but the ring gear flange is closer to the center of the diff than my 3.08 carrier so I think it's 3-series. They have the ring gear moved closer to the center because the pinion is smaller, right?
So, assuming this is a 3-series, will this work in my car if I get 28-sp axles and a new set of gears?
And, what is it worth if it's in good condition? I thought $100 was a steal, but if I have to put in a new clutch pack and bearings, it might end up costing a lot more
Thanks for your help, I love these kinds of forums
Old Sep 13, 2004 | 02:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, the pinion on the higher-numbered ratios is smaller, so the flange is closer to the center.
Auburn sells parts and will rebuild it; it will cost nearly as much as a new one though. You'll never guess how I know that.
Yes it will work in your car, with 90-92 axles.
$100 is what SLP was charging for them straight out of breand-new cars, if it's the stock one. So if it's used, .... you paid the same as you would have 5 years ago, for new. You'll have to be the judge on whether that's a "deal" or not.
There's 3 "levels" of them; stock, "High Perf", and "Pro". The springs are a different color: no color for stock ones, yellow for HP, orange for Pro. There may be other differences as well, but that's a quick visual ID of it.
You'll need new bearings; there's none on it.
I liked the one I had, until it self-destructed.
Old Sep 13, 2004 | 03:26 PM
84camaroBC's Avatar
Engine: LG4
The springs are yellow, so I guess I got a hi-po one.
It is used, so it wasn't such a good deal...
Oh well, anything is okay as long as it gets rid of ol' peg-leg
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
Linson
Sep 21, 2015 01:08 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
