GM 14 Bolt
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
GM 14 Bolt
i can pick up a gm 14 bolt from on old chevy 2500 out of a junkyard for like $75 bucks they quoted us. would this be worth it and able to handle my cars 500+ hp and 500+ tq?
if and when i buy that what will i have to do to it to make it swap into my car???
thanks
Ben
thanks
Ben
Car: 1985 Trans Am
probably have to have custom axles made with a 5 lug pattern, about $350, and have the housing narrowed. making the brakes fit will probably be a pain too, i don't know how you'd make the torque arm fit.
i know how you would make the torque arm fit , youd have to make a bracket just like mine has. If you can do all the work yourself , i saw do it. It could be a fun little project. But your gonna need a junked thirdgen rear to get all the spring perches off . And to take measurements.
Car: 1989 C4
Axle/Gears: 307
I used one in the truck when I had the BB 402. It was a 4.56 ratio posi and held up quite well. I had a set of custom rims built by a local low rider shop to retain the factory drums and brakes. The rims were very expensive and barely fit over the drum. IMO you would be better off geting a drop in setup like in the pics above.
Car: 1991 Z28
Engine: 383
this would just be nice if i could get it to work. i know they are very strong and i wouldnt have to spend almost $2000 on a rear end.
so i would need:
get custom 5 Lug axles?
weld spring perches?
weld spot for panhard bar?
weld spot for shock mounts?
make torque arm bracket?
and im sure the posi is probably shot so i guess id cahnge that with the gears
when you said narrow the housing were you talking about the axel tubes?
and as far as the brakes could i get a set out of the junkyard to work?
so i would need:
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Thats it guys, I'm just gonna go find a rear from a 1975 3500 dually and see if it'll fit in a 3rdgen. I'll put 4 slicks on the back and think I'm cool.
Car: 1991 Z28
Engine: 383
WTF
anyway apparently there isnt many 14 bolts running around here. i thought there would be more people with them on their cars. since they are strong and pretty cheap to first buy. i know it takes quite a bit to get one to fit but is well worth it.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The 14 bolt rear end out of a truck is way overkill for a thirdgen. Too heavy, too big, and it much stronger than you will EVER need. For the money you would spend convincing it to go in there, you could have a very nice 12 bolt made for you, that would bolt right in.
I think a Thirdgen dually would be just too weird.... LOL
Car: 1985 Trans Am
the centersection of the 14 bolt is a lot bigger than a 9 inch or 12 bolt, might be kinda hard to fab a torque arm bracket, but probably not impossible. The posi may not be shot, as if it even has one, it's likely the gov-lock carrier, kinda like a locker, no clutches. i've got a 14 bolt in my truck now, and it looks like it would be kinda awkward under a thirdgen, but may work.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
If you go with something huge like a 14 bolt its not going to be as efficient as something smaller. Theres a guy here that put in an 8.8 ford into his camaro and its as strong as a 12 bolt, way quieter than a 12 bolt or 9", and also is more efficient and requires less power to turn the internals.
Car: 1991 Z28
Engine: 383
thats true....its damn huge!!!! but they only wanted $75 and i figured it would be cheaper than a new 12 bolt or 9" but o well. besides i would love to break it!!!
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i had one in my 83 chevy dually quadcab but it fit under it just fine ...LOL..it also had 4.56 gears in it but i dont see how even when purchasing it for 75 bucks it could be cost effective when you have to have every thing else around it made to fit.
not to mention the weight of it alone...
or the bulkyness of it i dont know if you would fit it under the car and keep a gas tank in place under there and if you did i dont know how well the exhaust would run around that beast.......
if it were me id do this to a 12 bolt first or buy a 12 bolt ready to go .
all honestly you can build a 10 bolt to handle 500hp
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i dunno about 500, but you could prolly put some good numbers through one with a good posi, aftermarket axles, support cover, welded tubes, on a foot brake car. cant have the shock of a manual or trans brake, thats what gets em
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
