Check this out...
Old Sep 21, 2004 | 02:44 PM
Z28LeavinU's Avatar
Car: 1984 5.7L Z28 H.O.
Engine: 4-Bolt 350 5.7L Carb
Transmission: 700R
Check this out...
About 2 months ago my tranny gave out, worked when cool, and just stoped working when warm, im pritty sure it wasnt shifting and thats what caused it. today i took the pan off just to look and it was real nasty, thick black gunk covering the pan and that little magent thing, then in the filter i knoticed metal flakes. now im wondering, chould my transmission have just maby a week or 2 of life left if i put in a new filter? i only have 2 weeks till i have enough money to put my th350 in. so i figure if the filter was clogged that chold be causing my problems, because it does work nice when cold.
Old Sep 21, 2004 | 04:42 PM
sellmanb's Avatar
Car: '86 Berlinetta
Since you're junking the tranny in 2 weeks anyways, replace the filter and tranny fluid, and make sure that you have AAA
If it's like this for months then I dont see why it wouldnt last you another 2 weeks. Of course you know as well as I do that replacing the tranny fluid and filter will not be a permanent fix, but it should work for the next 2 weeks. (If it doesnt, dont come hunting me down )
Old Sep 21, 2004 | 05:34 PM
Z28LeavinU's Avatar
Transmission: 700R
problem
got a few problems, im pritty sure i have the filter stuck in the right hole, only hole i saw, and i got it as far in as it seemed it wanted to go, but when i try to bolt it on i get one corner on, go to the other side and i cant get it to sit flush. i also cant seem to keep the gasket clean while doin all this.
Old Sep 21, 2004 | 08:24 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You need to make sure that the old o-ring (metal ring coated with rubber actually) from the old filter has been removed; they like to stay in the pump when you pull the old filter out. That will cause the new filter (with its additional new sealing ring) to sit lower than designed..
Old Sep 22, 2004 | 06:06 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Ditto on the ring. Clear the old gasket out of the filter tube and then reinstall.
Jim.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Numbah-1
Sep 12, 2015 08:57 PM
