Stripped pan bolts/ Rubber gasket?
Old Sep 22, 2004 | 12:54 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
A few of the holes on my transmission are stripped the bolt just spins. What is the procedure to fix this. I know i will have to get a thread cleaner but will i need to then use a bigger bolt?
Do they make rubber tranny gaskets for the 700r4 not cork?. My tranny is leaking like crazy since my last filter/fluid change.
What type of oring should i use for my drainplug it has some big palstic one should i leave that or go to a rubber one?
Old Sep 22, 2004 | 04:36 AM
ede's Avatar
ede
either use a thread insert or drill and tap to next larger size. try leveling out the dimples in the pan and fixing the stripped bolts and your leak may/ought to go away. i'd leave the drain plug as it came.
Old Sep 23, 2004 | 12:05 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Stripped pan bolts/ Rubber gasket?
Heli-Coil
Genuine GM
I don't like drain plugs
Old Sep 23, 2004 | 02:21 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Plain cork is quite possibly the worst gasket material conceved by mankind. I dont know why gaskets made of it are still available.
Old Sep 23, 2004 | 09:11 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
depending on how bad the bolts are striped you can use some mech. wire and force the bolt in. It will (the wire) be squezed into the hole to keep it tight. We use it all the time.
However if more than 2 or three or if they are beside each other I would say Helicoil
There are a few other options on pan gaskets. Cork will work fine if you have a flat surface and don't overtorue it
The steel lined rubber are prob the best but not really nessary.
unless you have a bad pan.
Old Sep 23, 2004 | 11:09 AM
FAST RS's Avatar
Where do i get the steel lined rubber one from? Any part numbers? The pan i got is a new pan i wanted to have access to a drain plug and it was 20 bucks for the pan so i figured why not. But now i have leaks before i had none. How ever the gasket i had before was a beefy cork one the one on there now is some dinky thin deal. But i would rather go rubber since i know they are better anyways.
Old Oct 13, 2004 | 10:42 PM
jmd's Avatar
jmd
Who cares if it's thin. The GM one is thinner than cork, but it works better. No idea on the steel lined rubber. Since the pan & trans are (reasonably) flat surfaces, there's not much reason for there to be a steel core in a trans. pan gasket.
Old Oct 13, 2004 | 10:52 PM
FAST RS's Avatar
I went to napa and got a rubber gasket last week i just need to find time to put it on.
If i get one of those thread cleaer things they sell would that help the stripped bolts? Or should i just drill the hole bigger and put a heli coil in. I have never used a heli coil before.
Old Oct 13, 2004 | 11:04 PM
jmd's Avatar
jmd
Sounds like from your first post a heli-coil would be in order. They're not bad to use; just take your time and follow the instructions.
Old Oct 13, 2004 | 11:07 PM
FAST RS's Avatar
Will I have to use a different bolt or can i use the one that is on there still?
Old Oct 13, 2004 | 11:17 PM
jmd's Avatar
jmd
a helicoil works as follows:
drill out the existing hole larger with the correct bit.
tap it with the correct tap.
install the coiled square cross-section wire insert with the driver
knock off an end-piece of wire (that is used during install only)
This lets the hole be restored to original thread size & pitch. That's what I'd do. No reason to go with another size.
Old Oct 13, 2004 | 11:19 PM
FAST RS's Avatar
Cool thanks
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Amillionoh7
Sep 5, 2015 11:44 PM
