Transimission Rebuild, what to look for
Old Sep 23, 2004 | 07:33 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I will spare eveyone with my transmission problems. But the fact of the matter is I need mine rebuilt. I am going to go to a very relaiable trans shop, and I was wondering what things should I request or look for in this rebuild. My engine was a LB9 swaped to a L98 that is stock, but I want something that will last and will be able to handle more mods with ease. I know about getting things like a Vette servo, Trans Go shift kit and a .500 boost valve ( even though I dont know what the boost valve really does, I just know its a common mod). Any Imput would be great.
Kevin
Old Sep 23, 2004 | 10:42 PM
Pro Built Automatics's Avatar
Take a look at one of my kits, Go to http://www.700r4l60e.com/store/custo...&cat=19&page=1 this will give you an idea of what you should use.
Old Sep 24, 2004 | 11:59 AM
Engine: L98 350 TPI
For the options below that are avalible in your rebuild kit can you explain what they are/ do?
GM reverse/input drum
GM HD sunshell
Rear Planet
Sealed Power Beast
Kevin
Old Sep 24, 2004 | 02:46 PM
Engine: L98 350 TPI
TTT
Old Sep 24, 2004 | 03:07 PM
Depending on how much horsepower you have will determine if you need the Beast (550 & up) & instead of the GM sunshell. The rear planet & reverse input deum are options if yours is bad.
Old Sep 24, 2004 | 08:57 PM
Engine: L98 350 TPI
Just to expand my knowledge, can you explain in more deatail what there and how I know if I need a new rear planet and/or reverse imput deum. Sorry for my unknowingness on transmissions, this is one thing I am trying to get to know more about.
Kevin
Old Sep 28, 2004 | 12:58 AM
Engine: L98 350 TPI
TTT
Old Sep 28, 2004 | 02:36 AM
If the 2-4 band is burnt, then most likely you will need a drum. If the drum surface is not flat where the band rides, then you will need a drum. If the rear planet has to much play in the pinions, and/or they are burnt, it will need to be replaced. If they are burnt, then you will need to replace the matching ring gear.
Old Sep 28, 2004 | 11:45 AM
Engine: L98 350 TPI
Hey Pro Built. I tried to PM you a few times but you inbox was full so I will ask you here. I am gonna get my tranny built from a place in Mondelein, IL called Jimmy's Transmissions. I heard from a reliable source that you know him. I was just wondering if this was true.
Kevin
Old Sep 28, 2004 | 01:30 PM
It's has been a few years, and his specialty then was 2004R's. Have him give me a call once he starts on yours.
Old Sep 28, 2004 | 02:42 PM
Engine: L98 350 TPI
Very cool! I sure will have him call you.
Kevin
Old Sep 29, 2004 | 02:04 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Dont question me Kevin :-) I told u so.
Pro-Built is a A1 guy and super knowledgeable, i talked with him about my 700 for my Formula when we started talking about hard parts and development is when I found out he knew Jimmy.
I dont think I would have any issues with either individual. Both back their work and have many cars out there to prove it.
Only reason I went with Jimmy's is , he is closer than PB to me and I get a little slack cut cause I'm running two of his now :-)
One 200 and one 700
later
Jeremy
Old Sep 30, 2004 | 02:39 PM
Engine: L98 350 TPI
Jeremy
I called Jimmy yesterday. I just need to give him a credit card # so he can order the converter, then it will be going to his shop in the next few days.
Also Pro Built,
Thank you very much for helping me out with this!! Also Jimmy said you have his number. LOL
Kevin
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
