t-5 trans mount
Old Sep 23, 2004 | 08:20 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
t-5 trans mount
Ive owned my 89 camaro rs for just about a month now and have already ripped 2 trans moutns in half is there somethign i dont kno i try not to beat on her but ant turn down a good street race is there anythign i can do to aviod replacing trans mounts constanly?
Old Sep 23, 2004 | 08:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't use stock GM rubber ones. It is not uncommon to have a new rubber mount break hours after it has been installed. Go with a poly mount of your choice. Also, look at your motor mounts. If they are shot the tranny mount is taking the brute of the motors deflection and can contribute to premature failure.
Old Sep 25, 2004 | 10:01 AM
Car: 87 Formula
Engine: 350 tpi
is it possible to use a solid tranny mount in conjunction with solid motor mounts? if so im gonna have my friend make me one for the new engine also where can i find a poly mount?
Old Sep 25, 2004 | 11:13 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
well if you don't mid getting shaked apart. with those straight motor and tranny mounts. just got with the ES polly mounts
Old Sep 25, 2004 | 11:27 AM
Car: 87 Formula
Engine: 350 tpi
well youll lose 4-5 punds of torque (sp) im boulding a new motor and dont mind some silght vibrations my dad has solid motor mounts in his chevelle so i kno what itll be like if i get a solid trans mo9unt made should i get somehtign stiffer made up for the torque arm?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
