what gear set to go with?
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
I'm getting the 2.73's replaced on my car next week and I want to make sure to get the right gear set. I want 3.73's but looking around on this board makes me think it might be a little to high? should I go with 3.42's or 3.73's? also, what will be the concequences of changing to a higher ratio?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
You can get lots of info on gears if you use the "search" feature. Most people on here have said that for the 305 TBI the best all around gearing is 3.42. That way you get improved accelleration without sacrificing a ton of gas mileage. The only consequence of changing gears is that you will most likely have to change your speedo gears as well. Good Luck!
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
