gearing question on highway
Old Sep 26, 2004 | 11:04 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
hey guys i have 2.73 gears and i'm going to be instlaling 3.42's this winter, i do quite a bit of highway driving.. how much is this going to effect the speed? i usually run at 80 at about 2500rpm and 100 at about 3000rpm... if i put the 3.42's in am i going to be like 80 at 3000rpm or more or just a little bit more rpm? thanks
by the way i have a 350 bored .030 over, lt1 cam, tpi heads, edelbrock performer tbi intake.. blah balh blah what i'm getting at is it's not the 305 that was in the car and i was told if you have a 305 you shouldn't do the 3.42 swap unless you go as far as to get a cam and intake and a couple other things
Old Sep 26, 2004 | 11:33 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Use the calculator section on the main page to figure out your RPM difference at speed.
Old Sep 26, 2004 | 11:54 PM
Car: 89 trans am
Engine: 355
uh, here is what i put:
Tire Radius RPM Rear End Ratio Transmission Gear Ratio =MPH
15 / 3000rpm / 3.42 / 1.00 (3rd gear?) / it came up with 78mph??
if it's that much off what do you think a top speed would be?
Old Sep 27, 2004 | 01:09 AM
vjo90RS8's Avatar
Car: 2002 Z28
with 3.73s i run at about 3000rpms @ 80mph in overdrive. Not too bad, im used to it by now and i still get about 23mph on the freeway with mods in sig.
Old Sep 27, 2004 | 01:51 AM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
Old Sep 27, 2004 | 08:08 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will need to change your speedo gears in order for your spedomoter to read correctly. If not your limiter will now be reached much lower.
Old Sep 27, 2004 | 10:21 AM
Car: 89 trans am
Engine: 355
alright... where can i get the speeo gears? my speedometer is aleady off but i'd hate to make it worse. got a site?
Old Sep 27, 2004 | 11:18 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
A few searches should give you your answer.
Old Sep 27, 2004 | 12:22 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
www.700r4.com sells all the speedo gears.
I calculated that with the 2.73s @ 80mph you're at 2000rpm. With the 3.42s it goes up to 2500rpm. I wouldn't be trusting your stock tach. Mine over reads by about 500rpm.
Robert
Old Sep 27, 2004 | 12:44 PM
vjo90RS8's Avatar
Car: 2002 Z28
dont get your speedo gears from 700r4.com, get the part numbers from the FAQ section of the boards and go to your local dealer, they are so much cheaper. Remember too that your actual RPMs will be alittle lower than what you get from the calculator due to the torque converter lockup.
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
