Q about front axle; help please!
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
How much would it cost to replace the front axle, given that it is bent? I hit a curb (w/ the sidewall/rim of the left front tire) and went up on it at about 15mph. I'm pretty sure the front axle is bent and thus I was wondering how much it would cost to replace parts+labor. Also, would using a front axle from a junkyard be just as good as getting an oem/factory one? Thanks for your time.
BTW I have a 92 RS w/ 305 tbi& 700r4 just in case this matters...
sorry if this is in the wrong section. I searched first and came up with nothing.
Engine: B18C1
thx for ur help but how much would the spindle (i assume this is what connects the two front wheels) cost to replace?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The two front wheels aren't connected at all, that's why there's no axle. There's a spindle on each side that sticks out for the wheels to ride on. I'll try to post a picture later.
I don't know how much it costs to replace, I've done it myself but never had one done by a shop. According to the book it's about 1.7 hours though. If you've hit a curb you may have other damage, the best bet would be to take it to a frame shop and get them to check it and give you an estimate.
The tie rod(s) will usually take the damage on a hit like this.
Plan on somewhere between $150 and $1000 dollars. For more accurate estimates...take it to a garage and have them look at it.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
A shop will charge between probably $150 and $750 or so depending on if they find anything else wrong with it, and the $150 price won't include an alignment.
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Oct 7, 2015 08:35 PM
downsouthboy
Aug 29, 2015 11:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
