Yet another speedo gear question/T5 swap
Old Oct 2, 2004 | 03:40 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
I plowed through the search, but couldn't quite get the exact info I needed. I'm swapping in a '91 WC T-5 into my '78 El Camino and need to convert the trans from vss to cable. I need to know the tooth count for cable driven T-5 speedo gears.
Rear end gears: 3.73
Tire size : 245/50/16
Tooth count, part numbers, whatever else I might need TIA!
Old Oct 2, 2004 | 09:00 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You need a 7 tooth drive gear and a 22 tooth driven gear.
Old Oct 2, 2004 | 11:27 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
http://www.hanlonmotorsports.com/T5Speedo.asp
Jorlain
Aug 24, 2022 05:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
mizz0313
Aug 12, 2015 06:45 AM
beachrodder
Aug 7, 2015 04:27 PM
