crossmember question
Old Oct 9, 2004 | 03:27 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
i am in the middle of putting a th350 in an original 700r4 90 camaro. the 700r4 crossmember is not lining up. what crossmember should i get (cheap) its a short shaft th350. thanks
Old Oct 9, 2004 | 07:08 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The correct factory-style crossmember would come from an 82-83 thirdgen with a non-overdrive trans - either the 3-speed auto or a four-speed manual.
Then you will have to tap out the forward holes on the framerails to install bolts to hold it in place, as the crossmember sits forward of the where the 700R4 one sat.
Old Oct 20, 2004 | 05:05 PM
bubbz89's Avatar
Car: 1990 RS
thanks so much... thats the answer i was looking for.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
87iroctheo
Dec 4, 2016 11:47 AM
deracer
Apr 11, 2016 12:04 AM
downsouthboy
Aug 29, 2015 11:29 AM
redmaroz
Aug 16, 2015 11:40 PM
