something let go and is grinding
Old Oct 11, 2004 | 12:05 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I just had a new tranny and stall converter (art carr) put in a couple months ago. Tonight while driving, this grinding noise started coming from the flywheel area. Here are the symptoms
Idle in any gear - no noise
Park and step on gas - grinding noise
Forward gear and step on gas - grinding noise and the car does not move
Reverse gear and step on gas - griding noise and the car does not move
The grinding noise sounds like if you put a gear on a drill and spun it against a piece of metal.
The only way I limped my car home was to keep it in drive and not press the gas. It was able to idle home, but I had to blow through the stop signs because it was very hard to get moving again once I stopped.
Any ideas of what let go? Torque converter? flywheel loose?
Old Oct 11, 2004 | 12:51 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Torque converter to flywheel bolts came out........
Jorlain
Oct 8, 2015 01:57 AM
hdis2002
Sep 8, 2015 02:52 PM
solocus
Sep 2, 2015 12:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
hokis
Aug 9, 2015 03:57 PM
