4th gen pedals help
Old Oct 11, 2004 | 11:57 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
4th gen pedals help
ok now i cut off the gas pedal and drilled out the holes for the booster and ig ot the 4 bolts to bolt up... how ever the top bolt is way off did everyone else use it??? or is it ok with out it???
can i just drill a new hole for it?? or what
Old Oct 12, 2004 | 12:21 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
same deal.. i just chopped it off.. kinda an overkill thing
Old Oct 12, 2004 | 01:37 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
were you able to get the top bolt to go in and line up?
Old Oct 13, 2004 | 08:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
on my setup, I didn't use the top bolt, but I did use the gas pedal. The entire 4th gen assembly went into the car with no problems.
Old Oct 18, 2004 | 08:06 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Hey porkyzilla I ran into the same problem this weekend when trying to install the 4th gen pedals. i was not able to get the hole to line up so i modified the small bracket to make it fit and it worked like a charm!
:lala:
Old Oct 18, 2004 | 09:02 AM
kevinc's Avatar
Car: 1982 Z28
I redrilled the top hole to align w/ the hole.
Old Oct 18, 2004 | 02:44 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
ok so do i have to redrill it and tap it??
or can i just leave the top bolt out??
Old Oct 18, 2004 | 02:49 PM
-ZERO-'s Avatar
Engine: 305 H.O.
He redrilled the hole on the pedal assembly bracket to match up with where the bolt went into the car. basically what i did. just have to get under there with a flash light and play with it to get it to work right. i did this last night. and all is good. wasn't the funniest thing in the world but it worked out.
And as far as leaving the top bolt out. With everything bolted up, ( without that top bolt ) have some one step on the brake pedal while you have your head under there ( not under the brake pedal ) and decide for yourself. you'll see what im talking about.
Old Oct 18, 2004 | 05:57 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
ok i have an idea now :lala: ill see if i can redrill it on the pedal assembly i think ima make a business out of this haha make the perfect pedals that slip right in with no problems.... so basically a modded 4th gen assembly
Old Oct 19, 2004 | 07:07 PM
-ZERO-'s Avatar
Engine: 305 H.O.
Originally posted by porkyzilla
i think im a make a business out of this haha make the perfect pedals that slip right in with no problems.... so basically a modded 4th gen assembly
You better remember me when all that money starts rolling in!!!
Old Oct 19, 2004 | 08:50 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Hmm.. Mine went in no problem... I did have to cut the gas, and enlarge the booster holes.
Kevin D.
Old Oct 19, 2004 | 09:30 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
oh well.... haha i wanted to use my 120 dremmel anyway...it was no biggie...i just got to get that top bolt on heeh..
Old Oct 20, 2004 | 01:00 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
is the ls1 dif than the lt1 pedal set up
just a suggestion
Old Oct 20, 2004 | 07:14 AM
-ZERO-'s Avatar
Engine: 305 H.O.
just a suggestion
:shrug: The pedals that i got were from a 00' TA. What about you porkyzilla?
Old Oct 20, 2004 | 01:40 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
i have no clue ebay bought they are lt1 though as they have a little bit of rust
Old Oct 20, 2004 | 01:42 PM
-ZERO-'s Avatar
Engine: 305 H.O.
o well. Did you ever get that top bolt in yet?
Old Oct 20, 2004 | 01:50 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
in about 20 mins hehe ima finish everything up...got a friend commin over hopefully i can finish the body work too...have her done
Old Oct 20, 2004 | 02:04 PM
-ZERO-'s Avatar
Engine: 305 H.O.
:rockon:
19irocz85
Aug 30, 2015 10:03 PM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
