Trans brake??
Old Oct 14, 2004 | 12:27 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Trans brake??
Hey guys, I'm probably gonna buy a th400 from probuilt soon and I was thinking that aroudna 3300 stall would suit my car pretty good, Now my question is when you have a trans brake does that allow you to launch at any rpm you desire or only lets u go to your max stall without any power to the wheels?? I have a t-5 now and I leave the line at 4500rpm and pull 1.7 60-foot times and I am afraid that without being able to launch it that high I am gonna lose some tenths and also cause of the power the 400 pulls.. Now am I right here?? any suggestions?? thanks
Old Oct 14, 2004 | 12:45 AM
Pro Built Automatics's Avatar
If you match the torque converter (stall) to the drivetrain, suspension, & tires, you can have better 60 foot times than the stick, and be easier on the driveline.
Old Oct 14, 2004 | 01:03 AM
Car: 89 Formula
Engine: Carbed 5.7
really?? that sounds great.. so what your saying is I don't really need a transbrake at all?? Now I have 90/10 drag struts, v-6 rear springs, edel. panhard rod, and some lakewood LCA's oh yea and no front swat bar and skinnys, Now I went 12.70 with drag radials and wunt to go mid 11's when I'm done. Can your trans do this for me no problem?? Also what stall would you recomend and with a manual valve body what of pattern is it, forward or reverse, thanks
Old Oct 16, 2004 | 01:39 AM
Car: 89 Formula
Engine: Carbed 5.7
anybody?? anything???
Old Oct 16, 2004 | 04:40 AM
Just use the standard forward pattern full automatic. If you want to manually shift it you can, but when driving around town leave it in drive or overdrive, works best this way.
1992 Trans Am
May 10, 2023 07:19 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
Leggman1
Aug 6, 2015 04:15 AM
