Poly Trans Mount Help
Old Oct 14, 2004 | 10:52 AM
TravisZ28MAXX's Avatar
Car: 1992 Z28 and 1988 IROC-Z
Engine: both L98s one with SD and one with MAF
Transmission: both 700R4s
I installed a poly trans mount on my car over the weekend while I was changing a bunch of other stuff. So my problem is this, there is no way that my crossmember will line up with the center hole on the mount. So I installed it on one of the outer holes. My question is this, Am I going to have any problems with this setup, and has anyone else had any similar problems with their poly trans mount. BTW my mount is from Energy Suspension.
Old Oct 14, 2004 | 01:30 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
my ES mount aligned easily, i had to enlarge the center hole on the cross member as it would not fit the bolt/stud.
Make sure it is facing the right direction also...
Old Oct 14, 2004 | 01:35 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I had the same issue Travis. The center hole in the crossmember had to be enlarged to fit the bolt.
Old Oct 14, 2004 | 02:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, uses a larger bolt than the stock one.
Just file the slot a little wider.
Old Oct 14, 2004 | 05:18 PM
I also had to enlarge the slot on the crossmember, and I do have the mount oriented correctly, the curved side of the mount toward the rear of the car as per the instructions. but like I said the center hole on the mount will not line up on my car. I had to use the far left bolt hole. (the mount has three holes in the bottom for the two different types of trans mounts that it will replace. I had to use the one hole on the left side.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
NBrehm
Aug 5, 2015 07:57 PM
