Trans Am shifter in IROC-Z?
Old Oct 10, 2004 | 06:58 PM
Camarothunder85's Avatar
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
I am wanting to install a "T-handle" style shifter in my 85 IROC. I LOVE the look of the stock TA shifter but I need to know what parts to aquire to make the swap. Can I get away with just changing the **** or do I have to replace the entire assembly?
Old Oct 10, 2004 | 09:22 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Can't see why you can't just change the ****.
Old Oct 11, 2004 | 01:18 AM
Morley's Avatar
You need the entire shifter, they aren't the same. The good news is it is a simple swap.
Old Oct 11, 2004 | 12:18 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
The shifter **** itself is interchangeable. There is a staple type clip in the front part of the ****. Remove it with a screwdriver, then pull the **** off. Reverse the process with the T/A shifter ****.
Old Oct 11, 2004 | 05:05 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Yep,very easy.I had an ugly camaro one in mine with the button on top of the shifter.Like said above just take out the little staple style clip in the front of the handle pull the old one off and put the new one on.
Old Oct 11, 2004 | 05:21 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
I know with my 85 iroc the shift **** isnt held on by any staple clips. My 86 and both my 94's were. So you might just want to pick up a whole shifter assmbly off a t/a.
Bryan
Old Oct 11, 2004 | 05:40 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I replaced my T-handle **** with a camaro top button shifter on my Formula. It was a direct swap, took all of 30 seconds with a small screwdriver to pull the little clip out of the front of the handle.
I have a shifter and t-handle from a Firebird if you need to replace both units.
Old Oct 11, 2004 | 06:56 PM
Engine: 350ci V8
I just looked at the shifter I have now and I don't see a retainer clip on it so I guess I'll have to replace the whole assembly. Zepher, do you have a pic of the shifter and handle?
Old Oct 11, 2004 | 07:38 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Sweet, so its not just me.
Old Oct 11, 2004 | 08:05 PM
Zepher's Avatar
I can get you a pic later on tonight. It's a stock one out of a 92 Firebird that my friend and I stripped.
Old Oct 11, 2004 | 10:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Will these pictures help? the first one is the newer style that has the "U" shaped clip holding the **** on and the second picture is the old style ****. Like morley said, if you want to use the new style **** it would be best to swap in the whole shifter assembly. It can be done and the shifter assembly from a trans am will fit and work in an Iroc. I know because I have one from an 86 trans am in my Iroc.
Old Oct 11, 2004 | 10:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Oct 12, 2004 | 05:17 PM
Engine: 350ci V8
Does anyone have a tech article that gives a play-by-play of how to swap the shifters?
Old Oct 13, 2004 | 09:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Four mount bolts and two cables plus adjusting the park/neutral switch afterwards and that is it.
Old Oct 14, 2004 | 05:14 PM
Engine: 350ci V8
Sounds WAY too easy...
Old Oct 14, 2004 | 07:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just look at the pictures in my previous post to this thread.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
