Torque Arm question ???
Old Oct 15, 2004 | 02:11 PM
Rexer's Avatar
Car: 92 firebird
Engine: 3.1 V6
Transmission: 5 speed manual
Axle/Gears: t5 and standary rear end
another question, what sort of mountings/bushings are fitted on a standard V6 with T5 on the torque arm? and if these were to fail or go bad what sort of problems could i expect as i have a wobbly car at the moment , i know the tranny mount has gone but i suspect i have movement from this aswell.
thanks
Nick
Old Oct 16, 2004 | 08:09 AM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
My torque arm mount is gone and when my car goes into 2nd hard sometimes it bumps the floor. As far as I know every stock torque arm just got a crappy rubber mount. The poly ones are alot better than stock.
What exactly do you mean by a wobbly car?? Is the panhard bar in good shape??
Old Oct 17, 2004 | 03:11 PM
Rexer's Avatar
Car: 92 firebird
Engine: 3.1 V6
i dont know if the panard bar is in good shap, when i say wobbly car i mean when you touch the throttle the car sort of jerks back and forth, at first i thought it was somthing to do with some sensors or somthing but i have changed most of them now and i know the tranny mount is gone because as the car is jerking you can see the gear stick jumping up and down, if the tranny mount has gone and the box is moving around then surley it will have an effect on the rest of the drive train what do you think?
Old Oct 17, 2004 | 04:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might check the motor mounts. If one or both are shot, the motor will rock.
JamesC
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
