3rd to 4th(OD) at WOT???
Old Oct 15, 2004 | 04:11 PM
Sgt.D's92RS's Avatar
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
Is there such a part that I can add to my transmission that will let me go from 3rd to 4th(od) at Wide open throttle and if this part exists what is the GM part # ???
Old Oct 16, 2004 | 03:01 AM
Car: 92 RS
found out what I needed
Thanks anyway, I found what I needed from B&M!!!
Old Oct 16, 2004 | 08:59 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I also have the same question, since you know can you please share you information.
Kevin
Old Oct 16, 2004 | 11:16 PM
25THRSS's Avatar
Re: found out what I needed
The B&M valve will not allow full throttle in OD. It will downshift over 3/4 throttle. You need the GM "B4C" kit.
Old Oct 18, 2004 | 02:28 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My stock tranny in my 88 Formula allowed me to go 3rd to 4th at WOT. maybe it had the B4C installed.
Here is a little vid I took one night,
http://www.transamws6.com/video/130mph.wmv
Old Oct 18, 2004 | 04:06 AM
Car: 92 RS
Ok What #
So let me get this clear. I need the B&M 3-4 upshift kit at wide open throttle and I need some GM B4C kit!!!! What is the part # for the GM b4c kit????
Old Oct 19, 2004 | 06:22 PM
25THRSS's Avatar
You don't need the B&M valve at all, just the "B4C" kit. Do a search and you will find the part #.
Old Oct 20, 2004 | 08:07 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have the P# upstairs. I'll post it tomorrow as it's too far to go when I'm this tired.
Old Oct 22, 2004 | 08:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
B-Body fix kit:
So our tranny doesn't downshift into third:
Go with GM #8673948. transfixleo
-AND-
You can do the modifications yourself by taking out the TV plunger & sleeve. You will want to block the part throttle 4-3 downshift passages using a small allen set screw in each hole (2). Grind the outside of plug flush, blow off with air make sure plunger moves freely in sleeve, and sleeve goes into the valve body freely. Cost of two allen screws? about .36 cents.
ProBuiltAutomatics
One or the other, don't need both. . .
RBob.
Old Oct 22, 2004 | 10:26 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Do you have pictures of installing the allen screws? Just wanting to know.
Old Oct 22, 2004 | 12:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
http://w1.601.telia.com/~u60113744/t...tranny_wot.htm
RBob.
Old Oct 27, 2004 | 01:04 PM
ss400hp's Avatar
Car: 2001 NBM Z-28, 1987 Camaro
Engine: LS1, LS1
Axle/Gears: stock and stock
I own an 87 with the 700 R4 and when I swapped engines I left the passing gear cable unplugged, it stays in over-drive at WOT now when it didn't used to. Strange....... still need that kit though so I can hook it back up
Old Oct 27, 2004 | 02:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The only 'cables' would be the TV, gear selection, TCC, and speedo (VSS).
If you left the TV unplugged the trans will fry from lack of line pressure. This would also affect how the trans shifts.
The shift cable and the VSS would be obvious. That leaves the TCC which if left unplugged would not lock up, unless the trans was modifed.
RBob.
Old Oct 27, 2004 | 02:11 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
that passing gear cable you are talking about is a detent cable it doesnt just tell the tranny when u are trying to pass soem one.... you are going to blow ur tranny up by having that un plugged man id hook it back up asap if i were you trust me do a search and you will see that i am right about this...
Old Oct 28, 2004 | 07:48 AM
ss400hp's Avatar
Engine: LS1, LS1
thanks, I didn't know about that at all!!! I appreciate you guys telling me about it, I'll hook it back up today then.
Old Mar 24, 2006 | 04:48 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Rbob, link doesn't work
Rbob, I'm interested in either of these mods. I looked up 8673948 on gmpartdirect.com and it says "REPAIR PK" $11.80. Is that what I need? It does the same thing that you describe with the allen screws?
Appriciate your help. I'm going to Grattan raceway in May http://www.grattanraceway.com/ (South west MI). It has a 1/2 mile straightaway coming out of about a 50 mph turn. Needless to say, I'm going to need full-throttle overdrive since I have 3.43's. Can't wait, it's going to be nuts!!
Originally Posted by RBob
B-Body fix kit:
-AND-
ProBuiltAutomatics
RBob.
junior419
Apr 7, 2025 11:35 AM
Veaceonee
Sep 29, 2016 08:15 PM
F-body-fan
Sep 17, 2015 12:16 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rudolphschenker
Sep 4, 2015 02:41 AM
