Clunk when put in gear??
Old Oct 18, 2004 | 01:01 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys when it comes to automatic transmission when they clunk when being put into drive or reverse and such what is it usually, its got new u-joints and the trans had been rebuilt recently and doesn't slip or do anything bad once already in gear..So what could it be? thanks
Old Oct 18, 2004 | 01:26 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
More than likely your tranny mount is the culprit. Mine mad ethe same noise after I was in reverse, floored it then slammed it into drive on my 86 Z28. Easy thing to replace.
Old Oct 18, 2004 | 07:42 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
If it is the tranny mount, spend the extra money and get the poly mount! Defiantly worth the money!
Old Oct 18, 2004 | 12:51 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
*an agreement to all points above*
Old Oct 18, 2004 | 09:38 PM
Car: 89 Formula
Engine: Carbed 5.7
Lets say its not the trans mount and its not the u-joints or the t/a mount.. What mechanically inside of a transmisson woudl cause it to shift like it has a shift kit and clunk when being put into gear?? The trans was rebuilt about a year ago and doesn't have many miles on it and doesn't slip or anyting.. By the way its a 4l60E.. Thanks guys
Old Oct 18, 2004 | 11:21 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
could be in the rear end also only thing holding you in place is the brakes so anything from engine mounts to rear end gears
jeff
Old Oct 18, 2004 | 11:42 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I know what your talking about. Shifts real hard when you go from reverse to drive and makes a bang. I dont know what would cause that in a 4L60E, then again I dont really know all the possible causes with a standard 700-R4/4L60 either.
Old Oct 19, 2004 | 11:19 AM
-ZERO-'s Avatar
Engine: 305 H.O.
Prolly a dumb question!...... But have you even checked the tranny or torque arm mount yet??
Old Oct 19, 2004 | 12:04 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Hmm that's interesting to hear. When my 700R4 is in drive, and I put it into reverse, it clunks and the car bucks. ...And mine also shifts like it has a shiftkit. I dont know much about my transmission's history, but it has 130k on it and the fluid is a little brown. (doesnt smell burned) And it does not slip.
Oh and when I replaced my mount all it helped with was how it would bang when the tires let go.
Whatever the problem is, I think we both have it...
Old Oct 19, 2004 | 02:24 PM
Car: 89 Formula
Engine: Carbed 5.7
I checked the mounts today and there fine.. If I put it in neutral and grab the driveshaft I can turn it and hear the clunk in the transmission. Now I always thought it was just clutches and stuff in an automatic but theres somthing actually clunking liek a gear..Anyone who has rebuilt a trans please post, Maybe dana at probuilt could help out..
Old Oct 19, 2004 | 04:51 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Pinion could be a little loose in the rearend...
Old Oct 21, 2004 | 01:03 AM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
I have the same problem. I have changed all mounts, tranny, and torque arm. replaced the u-joints and have rebuild the rear end with new bearings and such. I thought that it mighta been the backlash but that wasn't the culprit. I still have the clunk to this day.
Old Aug 27, 2008 | 02:39 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Clunk when put in gear??
tranny mount
or perhaps too much backlash in the ring and pinion gear
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
BlackBoulder
Aug 11, 2015 11:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
