How do you get a t5 apart.
Old Oct 18, 2004 | 01:10 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I'm trying to get this plate off to check the gears before it goes in the car. I really don't know what i'm doing, I just unbolted it and knocked it loose. But I guess it is attached to the rod that goes to the shifter, and now I cannot get it back together right either. Someone want to give me an idea how to get it loose, thanks.
Old Oct 18, 2004 | 01:15 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Ok, so I did a search and found out half the damn tranny has to come apart to get that off. Is their any way to get the thing back on or am I going to learn how to dissassemble a t5?
Old Oct 19, 2004 | 09:42 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
wiggle the lid to get the corner bolts with the shoulders to line up, then its cake...
its actually pretty easy to take it aprat and back together...just gotta take your time and pay attention..
if you want to take it apart, the first thing you need to do is buy some tools...you need a 3/16'' pin punch, lock rings pliers, and a set of universal snap ring pliers (inner and outer)....make sure the tranny is in neutral....take out the 6 16mm bolts that hold the tail shaft on and pry it away from the case (carefully its aluminum)..get it back to were it cant go farther becasue the shifter offset block..drive that pin out and remove the block (theres a ball and spring under that so be carefull) and the tailshaft will came right off...once its off you can take off the cover lid...
Id suggest getting a rebuiuld kit if your going to tear it apart
www.hanlonmotorsports.com
Old Oct 19, 2004 | 06:56 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
about 275hp J/K
Old Oct 19, 2004 | 07:54 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Originally posted by 88 350 tpi formula
about 275hp J/K
Don't forget to dump the clutch just to make sure it comes apart
Old Oct 20, 2004 | 03:51 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
with slicks in 2nd gear works better
im at about 370 RWHP and im pretty hard on it...i dump the clutch and powershift it very aggressivly...although it just breaks the tires loose on the street, to the point were i have to get out of it to keep the @ss end behind me...
KCG
Jun 24, 2020 04:33 AM
machinist21
Sep 5, 2015 03:03 PM
masonta
Sep 1, 2015 06:40 PM
E_S
Aug 29, 2015 04:09 AM
