Need help choosing an aftermarket FlexPlate!!
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Going to be replacing my stock trans with an aftermarket street/strip trans and want to replace my stock flexplate with a stronger one. Which manufacturer do you guys suggest I go with?? Also this will be going on a 91 RS 305TBI....what is the tooth count on my flexplate. Also does it matter if I get a internaly or externaly balanced??
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I have a B&M SFI aproved Flexplate and I am happy with it. There is a big difference in the thickness than stock.
Kevin
Kevin
