9-bolt Weight Compared to 10-bolt
Old Oct 21, 2004 | 04:18 AM
3rdGenBlackBird's Avatar
Is there any weight difference between 9 and 10-bolts?
Scott
Old Oct 21, 2004 | 04:44 AM
ede's Avatar
ede
most likely there is. WAG the 9 bolt will be heavier. would it really matter?
Old Oct 21, 2004 | 05:57 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I don't have numbers but I can assure you that my 9 bolt just about made me rupture a disc when I was putting it into hatch area for the ride home from the yard! The center section is a good chunk of cast iron. Made the old 10 bolt look like it was made out of cardboard. Not that the 9 bolt is all too impressive with a 7.75 ring gear, but that is weight you WANT to have. One of the 10 bolt's main weaknesses is the wimpy housing that likes to flex. In conclusion, the 9 bolt is heavier.
Old Oct 21, 2004 | 11:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I was going to say the same thing. the 10 bolt seemed fairly easy to lift but, the 9 bolt seem much heavier. actual differance may only be 10 lbs if that but, feels like more
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
PurelyPMD
May 5, 2016 04:57 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
