rear end question
Old Oct 22, 2004 | 04:52 PM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
rear end question
Im wonder what rear end i have...
3.1 v6
When i peel out normally 1 tire will spin when so my friends say and the tread left on the pavement..but every now and then ill really get into peeling out and i will floor it and both tires will spin i have tread evidence to prove it...I dont have the RPO for a posi
Whats up with my car
Old Oct 22, 2004 | 05:23 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
3:23 open rear ( No Limited Slip) because no one would order a V6 car with one. RPO G80 is the option number. Waste of good tire rubber trying to burnouts,
Old Oct 22, 2004 | 05:43 PM
Car: 92 camaro RS
why do they sometimes both spin and sometimes one spin
Old Oct 22, 2004 | 06:14 PM
DJP87Z28's Avatar
Just like what came first the chicken or the egg. In other words "don't worry about it. It may be the road surface/
Old Oct 22, 2004 | 08:07 PM
Car: 92 camaro RS
oh so now when you have a question people just say dont worry about it.... .... ive never heard of that in my life....theres gotta be a reason i thought a non posi rear end only propelled one wheel.... ill just ask on iroczone since this site when down the drain
Old Oct 22, 2004 | 11:12 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
Well sorry you feel that way about the site! I will try to help... It is posible you have a posi. If you have not change you diff fuid in a while pull the cover off and take a look. Then you can know for sure if you have a posi and you give your diff some fresh gear lube! If it not posi it just could be the road suface. Hope this helps a little.
Old Oct 23, 2004 | 06:51 AM
Car: 92 camaro RS
thanks man...im putting my car on the lift tommorrow becuase i have to tighten up my exhuast cause it rattles and connect the o2 sensor..(not sure why thats not hooked up) and ill pull the cover off while its up there
Old Oct 23, 2004 | 07:48 AM
ede's Avatar
ede
why don't you go ask on iroczone like you said you were going to do? since this sites went down the drain so much as you say i sure wouldn't be lowering my self to the level of accepting advice from any one here.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
