still leaky th350
Old Oct 25, 2004 | 01:45 PM
dukemushroom1's Avatar
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
still leaky th350
well i swapped the oil pan, needed a new one anyway but it still leaks. i'm thinking it may still be coming from the cooling lines, i noticed a little bit of fluid around them the other day. and it's more of a drip now so there's not a lot of fluid loss. could i use some type of thread sealer on the cooling lines?
ljnowell's Avatar
wrap them with sealant tape. I usually do it on all metal fittings.
Old Oct 25, 2004 | 03:21 PM
ede's Avatar
ede
tape won't help anything of flare fittings. they should seal aginst the flare. tape may help o nthe fitting that goes into the trans case. did you level out the dimples around the bolt holes in the pan? o ring on fill tube good?
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
Catcher55
Aug 15, 2015 07:08 PM
