Money well spent on trans cooler!
Old Oct 29, 2004 | 11:56 PM
RICHRAD's Avatar
I always liked the way my trans shifted when cold especially the 1-2 shift. But when it got hot it was very sloppy.. Anyways a month ago I ordered a summit 10" x 17" transmission cooler and a B&M shift kit. I installed the cooler first to see if there would be a change in the shift firmness once the engine warmed up. Well man !, I think I'm going to leave the shift kit on the shelf now cause it shifts nearly as firm cool as when cold .I'd like a little more firmness in the 2 through 4 shifts, but I hear that the B&M kit is only good for the 1-2....So is it time for a different servo? or Transgo kit ? I'll get a pic of the cooler installed soon
Old Oct 30, 2004 | 12:09 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Trans-go kit if anything. It's the only kit that does all the "good" things to improve your trannies performance. Get a vette or billet 2-4 servo, along with the low-reverse boot valve and the mega valve and the other improvements that are in the trans-go kit. Oh, and get a new TV valve spring (the one that actually actuates the valve in the valve body when the plunger is pushed in). It might be included in the kit though.
Old Oct 30, 2004 | 12:16 AM
RICHRAD's Avatar
So will I be dropping the tranny now? If so, I might as well wait till I can afford a good performance torque convertor..
Old Oct 30, 2004 | 07:03 AM
thirdgen88's Avatar
Car: 1995 Corvette
I see a cascading effect in progress..
Might as well reclutch it if you're going that far..
Old Oct 30, 2004 | 12:24 PM
RICHRAD's Avatar
You mean a rebuild It only has 73,000 miles on the original trans. I'd rather wait till there's major slippage, which probably won't happen for some time with the cooler
Old Oct 30, 2004 | 09:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Sorry, thats just the way I think..
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
toronto formula
Nov 10, 2015 06:17 AM
jharrison5
Aug 19, 2015 05:53 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Exxon Limited
Aug 9, 2015 08:13 PM
