What RPM does Auto trans switch gears?
Old Nov 2, 2004 | 12:54 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
At what RPM does an automatic 700R4 switch gears? I think it only has 3 gears, since that's all I feel.
Before I took it to the tranny shop, it would switch gears at around 2500-3000 rpm and I would be cruising at 70mph with my rpm's around 1500-2000. This sounded normal to me.
After I got it back, it's now switching at around 4000-4500 rpm. When I first start the car and hit the gas, I would only go about 20mph, but it sounded like I should've been going faster because my rpms would shoot to 4000 before it switched to 2nd gear. This does not sound normal to me because normal for me was around 3000. Someone please tell me if I'm going crazy or not. I don't even know if what I'm typing makes any sense. Please Help!
Old Nov 2, 2004 | 01:18 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
the 700 is a 4 speed trans with overdrive I have a v8 and at wot it shifts at 5000rpm it depends on your throttle position more throttle the higher it shifts
Old Nov 2, 2004 | 01:34 PM
EvilCartman's Avatar
Car: '82 Z28
Sounds like you might need to adjust the TV cable. Do a search on how to adjust it, it's been covered a lot.
Old Nov 2, 2004 | 02:01 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
I found it. There was this little, metal wire at the very top of the engine. I think it was the throttle cable since every time I hit the gas pedal it moved back and forth. Anyways, it was a little dirty so I cleaned it and now it shifts correctly. Thanks to those that posted.
Old Nov 2, 2004 | 04:54 PM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
Yeah, that TV cable is what you wanted. Transmission shifting isn't entirely decided by RPM, its mainly decided by how far you've pushed the pedal (and therefore how far the cable has been pulled). I had the same problem when I had my 700r4 rebuilt (when floored, it would shift up at 2600 RPMS), and readjusting the TV cable fixed it.
Old Nov 2, 2004 | 06:40 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Originally posted by Cyfun
Transmission shifting isn't decided by RPM, its decided by how far you've pushed the pedal (and therefore how far the cable has been pulled).
Just to clarify a bit here, the shift point is determined by two variables: throttle position (TV Valve position and associated line pressure) and RPM (governer speed and governer pressure).. This is why you can change the governer weights/springs and affect both part throttle and WOT shift points.. The two (tv position and rpm) work together to determine the final shift point.
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
