700r4 mods?
Old Nov 7, 2004 | 01:52 AM
StaticVertigo's Avatar
700r4 mods?
everywherei look there seems to be an inexpensive part to make this tranny better and better ....
.500 bost valve - 10 bucks
corvette servo.... 12 bucks
what else is out there? anyone have a list or anything like that ?
i am going ot get a transgo shift kit monday....not sure if it comes with the .500 valve....some do, some dont....
there used to be a siter dedicated to nothing but 700r4 upgrades starting with the more simple things such as the servo, then goes up from there to *the beast* planetary gear sets and such.....
i REALLY wish i could go WOT in 4th without it downshifting to third.....the best it seems to be able to do is....3/4 throttle before itll kick down....other than that, i dont know of any mod thatll hold 4th no matter what....
700r4 doesnt seem nitrous friendly due this this.....using a WOT switch....makes it impossible to spray after third gear tops out.
shoot me some ideas....... post em or IM me on aim under AspiredTwo
Old Nov 7, 2004 | 04:39 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
gm sales a kit called the b4c upshift valve kit,makes you get wot upshifts into fourth gear.i payed 60 dollars for red alto 3-4 clutches,125 for transgo **** kit from summit,15 for 4l60e 2-4 band,55 for updated beast sun shell.
Old Nov 8, 2004 | 06:53 PM
o-ring or non o-ring .500 valve????
Old Nov 10, 2004 | 03:28 AM
Pro Built Automatics's Avatar
Either.
Old Nov 10, 2004 | 03:30 PM
this is a useless question seeing as how i already installed the non o-ring type, but which is better? o-ring im assuming.
i had to drop my pan BACK off today and put on a different pan due to the B&M tranny drain plug decided to leak like a SOB.
so i'll just buy a nice deep chrome tranny pan that holds an additional 2 quarts and has a real drain plug.
Old Nov 10, 2004 | 09:48 PM
jonarotz's Avatar
Car: 91 Z28
Here is a list of what I did.
I am thinking about the B4C mod next.
Probuilt,
Does this actually allow WOT 3-4 shift?
Old Nov 10, 2004 | 09:51 PM
jonarotz's Avatar
Car: 91 Z28
I also have the bigger boost valves installed
Old Nov 10, 2004 | 09:52 PM
i wish i had the ***** to take my tranny a part.....ill rebuild EVERYTHING but an automatic tranny....some things just arent ment to be, the auto trannyt is one of them...i fear it....
Old Nov 10, 2004 | 10:59 PM
jonarotz's Avatar
Car: 91 Z28
I have actually done a few, I learned by reading up on it and by just getting my hands dirty. If you ever get the bug to do it I would recomend buying a good manual and researching into it. One thing that always kind of helped me was a coment someone made to me,
"no matter how much you think you messed it up it is always fixable."
Sometimes the fixable part ends up costing some money but I guess at least you learned something. I have made many mistakes along the way but I learn from them.
Old Nov 10, 2004 | 11:03 PM
well, i learned EVERYTHING that way.....i never had anyone helping me, i just....grabbed manuals and read up .....found artcles, how to's and just kinda eyeballing stuff and figuring it out.....im just not in the mood just yet to rebuild a tranny when the one i have only has 5k on it since the reman.
i learned how to build rears and do gear swap by just reading about it...
Old Nov 10, 2004 | 11:08 PM
jonarotz's Avatar
Car: 91 Z28
I think that it is the only way. Good luck with what ever your next challenge is.
Old Nov 11, 2004 | 09:33 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
That is what I thought till I did it, it was a cake walk.
I upgraded to an Art Carr hardened input shaft with drum installed, Art Carr hardened stator support, and their "Beast Shell" that is hardened and comes with a torington bearing. I also installed the B4C kit from GM, a new TV sleeve that calls for a 90% throttle before downshift, a 5 pinion rear planet, Corvette servo, .500 boost valve, TCI racing overhaul, and topped it off with a B&M shift kit (The B&M shift kit is like a rotten cherry on top of an ice cream sundae compaired to a Tranzgo kit). I also had to rewire the Lock up since I no longer use the ecm.
I do wish that I had upgraded from the 10 vane pump to the 13, and installed the 5 gear front plannet too.
Old Nov 11, 2004 | 09:37 AM
i think whats throwing me of is the only thing i have taken off is the valve body.....once i saw all the check ***** fall oiut, and had no clue where they went...i said screw this....luckily that was on a old tranny.....was just experimenting......
one day soon i will tear the tranny a apart and learn how to rebuild them......just...not one day soon lol
Old Nov 12, 2004 | 06:20 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
If you really are interested in rebuilding one, get a 700R4 from the bone yard and try it.
But first get an ASTG manual for the 700R4 and read through it a few times. I had to make a press to get the servo out, and the press ended up working to take the rest of it apart also. Worked pretty slick, it was like a giant C-clamp.
PS. The ASTG book shows where all the check ***** go.
Old Nov 12, 2004 | 12:27 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
ATSG..
Automatic Transmission Service Group... GREAT manuals.. Get the blue one and the green one (the green one covers all of the updates that were performed along the years to the 700R4, the blue one gives you everything else)..
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
