8 Speed trans
Old Nov 9, 2004 | 06:58 PM
Burn EM!'s Avatar
8 Speed trans
Anyone look into buying one of these tail shaft replacements. Really intresting but kinda pricey.
http://www.gearvendors.com/index.html
Old Nov 10, 2004 | 12:37 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
You could do a 4+3 from a Vette for less $ & less floorboard fitment issues. Those are a Super T-10 which are strong, strong, and the 86-88 overdrivers aren't TV cable controlled, and do well; the earlier ones with TV cable had more issues.
or T56.
The GV OD units are good and work but you're right; for the $ there are other choices.
Old Nov 11, 2004 | 07:25 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
true, but where woul you find a 4+3 from a vette? that's not exactly common around here. i'd rather get the gear vendor because it's simple, straightforward, and has been done countless times with predictable results. and it's good for lots o' power.
Old Nov 11, 2004 | 10:38 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Ain't worth the cash IMO. Plus they have a history of grenading in the 50K mile range... fudge that...
Why do you want it? Gas milage?
Old Nov 11, 2004 | 10:42 PM
jmd's Avatar
jmd
eBay. You in Lawrenceville KS? A friend in KS just did the swap in a g-body for an economical amount. The 4+3 is a super T-10; it's good for plenty of power. The overdrives are too if it's the later one with boosted pressure.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
