what gears
Old Nov 11, 2004 | 11:50 AM
sprayedcam86's Avatar
Car: 86 camaro z28
Engine: wild 355 chevy sprayed with nos
what gears
i have an 86 z28 with a 355 in it running nitrous. i have a race built trany but the stock 292 rearend. all i plan to do is go as fast as i can in a quarter mile. im not really worried about fuel economy. so should i go with 373 gears or 410.
Old Nov 11, 2004 | 11:52 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
4.10's.
Old Nov 11, 2004 | 11:56 AM
Car: 86 camaro z28
i heard that only certain gears will fit. do they make a 410 replacement that will fit my stock housing. if you know of any try to find a part number. i would apreciate it.
Old Nov 11, 2004 | 01:33 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Dont know. What kind of rear is this? Stock 10 bolt? You could always get another carrier or a later model rear end with better axles and the higher series carrier to start off with.
Old Nov 11, 2004 | 01:51 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
you want a gear that will put you at peak power at the finish line.all depends on how much power your running and tire size.what rpm do you cross at now?
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
