Changing rearend gears
Old Nov 11, 2004 | 03:29 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Im lookin at buying a 92 lo3-700r4 rs and was wonderign to change the 273s in the rear do i need to pull the axle out or is it possible to do it with the axle in the car?
Old Nov 11, 2004 | 03:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's possible to do it in the car; but it's much faster, easier, cleaner, and overall better, to pull the rear. Kind of like changing a crank with the motor still in the chassis. Yeah, you can do it; but it's about twice as much work as doing it right, and alot more risky.
Old Nov 11, 2004 | 03:34 PM
Car: 87 Formula
Engine: 350 tpi
assuming there no problems how long do you suppose this would take?
Old Nov 11, 2004 | 03:55 PM
JesasaurusRex's Avatar
To drop the rear? All you gotta do is disconnect the LCAs and Panhard bar from the rear end only and disconnect the driveshaft. But i would assume you could do it with the driveshaft still attached, and just have it hanging hella low.
Probably about an hour for that. Now to change the gears I wouldnt know thats the only thing on my car I wont do myself.
jklein337
Sep 19, 2018 06:23 PM
Warlocksirix
Sep 3, 2015 12:26 PM
jbd1969
Aug 17, 2015 07:06 PM
86White_T/A305
Aug 17, 2015 12:16 AM
