bolts broken in the tranny crossmember
Old Nov 11, 2004 | 08:57 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
bolts broken in the frame for the tranny crossmember
well i was pulling the motor out of my carand went to take off the transmission crossmember. i looked at it and only saw 2 bolts. Two of the bolts are broken in the frame. now there is a nut welded into the frame right?
so what do i do here? drill a hole in whats left of the bolt and use my "easy outs"?
any suggestions here?
Old Nov 11, 2004 | 09:32 PM
ljnowell's Avatar
I would attempt the easy out route, that or try to weld a nut onto whats left and take it out.
Old Nov 11, 2004 | 10:02 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
there isnt much left of the bolts....and there rusted in there pretty good, but ive been soaking it with pb blaster lately
Old Feb 20, 2005 | 04:27 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
**** that just happend to me too. DId you get your bolts out with the PB blaster and easy outs?
BTW what exactly are "easy outs"?
Old Feb 20, 2005 | 05:58 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
just drill the whole thing out, about 1/16 bigger than the original bolts, and tap it for a larger bolt....those threads strip out often anyways.
Old Feb 20, 2005 | 07:27 PM
brutalform's Avatar
This happened to me too. I just took a 1" hole saw to the frame rail, and made an access to simply put a nut on the bolt. This is a regular problem on third gens...
hectre13
Dec 11, 2023 08:14 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Elliswon
Aug 10, 2015 12:33 PM
