rear end question
Old Nov 21, 2004 | 06:55 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
rear end question
i was just wondering if all third gen disc brake rear ends are the crappy 9-bolt?? or are some 10's???
Old Nov 21, 2004 | 07:04 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Most in fact are ten bolts but they are worse than the crappy 9 bolts. The ten bolt is a 7.5" ring gear with c-clip axle retention and the 9 bolt is a 7.75" ring gear but also has bolt in axle retention so it is better but not great.
Old Nov 22, 2004 | 02:43 PM
Car: 91 camaro rs
okay thats kinda helpful, the reason i was asking is b/c...
my 85 TA originally had a 9-bolt disc brake rear end and the ring and pinion was so worn out the teeth were sharp and it hummed and whined so i switched to a 10 bolt drum brake rear end,
i still have the disc rear end master cylinder in the car and im buying a parts car that has disc rear and i was going to be changing my gear ratio to a 4.10 from a 3.42 and i figured i could do the new gears in the disc rear, THEN swap THAT into my car, keeping the disc rear master cylinder, so as long as its the 10-bolt i should be fine right? because i know they dont make new ringa nd pinions for the 9-bolt...
Old Nov 22, 2004 | 10:07 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
um they do make ring and pinions for the 9 bolt i have one and randy's quoted me 166 for new gears
Old Nov 22, 2004 | 10:23 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Yes that should work out okay. You can get gears for the 9 bolt but the selection is very limited and forums_suck price of 166.00??? I think there was an error there as the last time I priced them out it was double that but it has been a while since I bothered with the 9 bolt. Good deal if thats the case. Regardless your twn bolt plan will work but don't expect that ten bolt to last long if you run slicks or pound it to hard. Good luck
Old Nov 22, 2004 | 10:26 PM
Car: 1983 Z28
Engine: 383
yeah i know it was a cheap quote the 10 bolt gears were 10 bux more which i made a point of mentioning to em.this was last week that i called if ya want the guys name and extension i think i still have it down here somewhere,im going to get a set before he changes his mind
So the nine bolts have a cone style posi like an auburn?I still havnt opedned up the one i picked up.
Old Nov 22, 2004 | 10:35 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Yeah its similar in design but not nearly as strong or good. Some guys have shimmed them up REAL tight with carrier mods but still a crappy rear IMO. Not very strong and noisy with oddball, hard to find, expensive parts.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
