how to take out t5
Old Nov 20, 2004 | 08:05 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
how to take out t5
it wont seem to budge. also what do i use to take out the speedo cable or what i assume to be the speedo cable it is on the tail housing.
jon
Old Nov 20, 2004 | 08:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Why would you try to remove it with the speedo cable still hooked up???
its held in by a 10mm bolt and metal clip next to it.
I found that it help putting it in and out if someone pushes in the clutch.
I assume your just pulling the trans.
And just un did the 4 bolts that hold it to the bell.
You also gotta take the shifter off.
Old Nov 20, 2004 | 10:40 PM
jocww's Avatar
shifter is off and the drive shaft is off im pulling the engine out. but i dont wanna pull it as 1 piece 2 pieces is easier. also thats what im having trouble with is how to take it off could u be more clearer on the speedo cable. and why do i have to have someone push in the clutch the slave cylinder is already disconnected so it doesnt really matter right if someone is pushing in the clutch or not
Old Nov 20, 2004 | 10:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
There r 4 bolts that bolt the tranny to bell housing. Just undo them and just take the tranny off. leave the bell. You don't need to push in the cluth, it just helps.
The spedo cable is held on / down with a metal clip. that is held down with a bolt. look around the cable end for it.
you also have the torque arm off??? its next to the drive shaft. giant metal thing.
Old Nov 20, 2004 | 11:53 PM
jocww's Avatar
trq arm is off 2. the tranny doesnt seem to want to budge do i move it up and down or what or side to side. how heavy is the tranny?
Old Nov 21, 2004 | 12:35 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
75 lbs. Get a large flat head screw driver and pry it back. Make sure you didn't miss any bolts on the top. Theirs one on the passenger side top that is a pita to take off.
Old Nov 21, 2004 | 07:58 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep just jerk n pull on it. Its not that heavy. I pulled mine alone. Just sat it on my chest. Installed it the same way.
One thing though. Has or did someone else paint it???
I ask cause i caused myself a bit of trouble installing mine as. The tranny has a round lip that goes into the round hole of the bell. well 4-5 coats of paint on that part make it a bear to get it installed. As its a real tight fit.
Took me an extra days work to figure that one out.
Old Nov 21, 2004 | 12:44 PM
jocww's Avatar
problem is i unbolted all the mtr mounts so the car is moving as long as the engine. anyway ill try it again an no it is not painted
Old Nov 21, 2004 | 07:31 PM
jocww's Avatar
both engine and tranny were out. newday started tranny came off in about 20 min i didnt know there was so many damn wires on the firewall
Old Nov 21, 2004 | 07:44 PM
musicfire67's Avatar
Car: 84 camaro
Transmission: stock 5 speed
Its a pain in the a$$, I just did it yesterday. What you need to do is push on the bell housing with your feet as far as you can. Then use a hammer and a screw driver to pry it out. Its hard but can be done
Old Nov 21, 2004 | 11:29 PM
jocww's Avatar
actually it only took 30 min maybe once i figured out how it should come out its a lil dif than the muncie. what kind of siphons are u guys using. and is the top plate the inspection plate.
Old Nov 22, 2004 | 06:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hand grenade
Old Nov 22, 2004 | 10:43 PM
jocww's Avatar
wat do u mean hg
