Th350/torque arm hook up
Old Nov 29, 2004 | 03:32 PM
TexasSteve's Avatar
Car: 82 Z-28
Engine: 350 bored 60 w/ vortech heads,crane cam,edelbrock intake & carb,hedman headers
Transmission: beefy th350
Can someone tell me how I can hook up my torque arm to a th350 other than buying the kit from b & m? Thanks in advance
Steve
Old Nov 29, 2004 | 03:50 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Th350/torque arm hook up
Steve
is the transmission in the car already??
if it isnt then you could use this kit..
http://www.bulkpart.com/Merchant2/me...y_Code=Teckpak
it works great my brother ljnowell has it installed in his car with his th350 and you get to use your stock driveshaft and your speedo hooks right up because you reuse the 700r4 tailshaft with the torque arm mount on it
heres a pic of his installed on the transmission ...
Old Nov 29, 2004 | 04:32 PM
TexasSteve's Avatar
Car: 82 Z-28
certainly appreciate your reply. I haven't installed the tranny yet,I am switching from a manual 4 speed to the th350. My mechanic told me to get a short shaft 350 which I did, so my situation is a tick different. I was told from a earlier post that my driveshaft should hook up.{hope so}
Old Nov 30, 2004 | 01:43 AM
CrazyHawaiian's Avatar
Car: too many ...
Short-tail TH350 will need a different driveshaft. Long-tail TH350 or a TH350 with the kit ljnowell used can re-use the 700R4 driveshaft. If the trans you have is a short-tail, I'd recommend the kit ljnowell and the general are talking about.
Old Nov 30, 2004 | 04:43 AM
ede's Avatar
ede
you can buy an aftermarket torque arm the has the forward mounting point in a bracket that bolts to the floor pan.
Old Nov 30, 2004 | 05:59 AM
TexasSteve's Avatar
Car: 82 Z-28
Thanks guys!
Z28/ZR1
Oct 23, 2015 01:04 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
raymondandretti
Sep 27, 2015 06:43 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
