why is my posi different
Old Dec 13, 2004 | 07:20 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys well i started rebuilding the used posi i got and i ecountered something wierd got it all apart and noticed that the case was two pieces, like there was a seam right down the middle and i had to take it apart to get the cones/sidegear assembly out? is that normal all the pics i see on here the outside of the carier is smooth and looks to be one piece. it was in good shape i was able to clean and resurface with 300 grit emry cloth all the slutch surface on the cones and case. so what kind of posi is this??? it had 3.23's on it so its a 3 series right??
Old Dec 13, 2004 | 08:37 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Sounds like a Eaton Gov-lock.
Old Dec 13, 2004 | 10:58 PM
1984HO's Avatar
Car: 1984 Z28
but the gov-lock has those wierd weight things that are visable through the inspection slot mine has the two paltes with the 5 spring s between them just like other auburn types ive seen it is just the case that is different. i just want to make sure before i invest any more time in it, the rearend that it came out of is definetly a camaro rear 26 spline drum brakes (87 i think it was).
are there more than one version of auburn type limited slips??
Old Dec 13, 2004 | 11:04 PM
1984HO's Avatar
Car: 1984 Z28
looks identical to this one
http://cgi.ebay.com/ebaymotors/ws/eB...category=33731
Old Dec 14, 2004 | 08:56 PM
Car: 91 Camaro RS
Looks like an older auburn unit, I don't know much other than that.
Old Dec 14, 2004 | 10:10 PM
1984HO's Avatar
Car: 1984 Z28
went to GM today and according to the exploded view diagrams it is an 86 or 87 unit but all parts are still availible so looks like my 50$ posi is ok
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
