What can i get manual pedals out of that will bolt into my camaro? or are the pedals f-body only? all info is appreciated
Any 3rd or 4th gen pedals will bolt in, but the gas pedal in the 4th gens is different so you'll either have to work out a way to use it or cut it off so you can keep your original. '82 and '83 pedals are for a manual linkage and will not work with a hydraulic clutch.
so pedals out of S-10's, or other GM cars wont work?
Not to my knowledge. The firewall and master cyl. linkage angles are different.
