manual swap
Old Dec 19, 2004 | 06:21 PM
chevcd2002's Avatar
manual swap
Hi I have been racing with a rebuilt 700r4 trans in my 89 camaro for the past year and I have been toying with the idea of converting to stick. The problem is finding a 5 or 6 speed trans that can hold up to racing stress. I never dynoed my car but I estimate that I am making around 650ft/lb of torque with a 150 shot of the go go juice. I came across these guys http://www.x2cmotorsports.com/tranny_shop.shtml
I know the first thing you think is that they are mustang guys but they claim that their rebuilt tremec tko 500 can reliably handle a 9 second 3300lb car. Lemme know your thoughts are I am very curious to see what you think. Thanks
Old Dec 19, 2004 | 07:32 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
is it a stock rebuilt 700r4 you have been running
the t56 is very beefy stock. are you running slicks or planning on it?
Old Dec 19, 2004 | 07:36 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Maybe Brutalform will chime in. He was makin 750+ ft lbs with his combo. He used a tremec trans that held up and worked perfectly!:hail:
Old Dec 20, 2004 | 03:05 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
here we go t56 is the only way to go...a centerforce will hole 700hp according to the tech department at centerforce for the lt1 than the slp steel billet light flywheel 19lbs...and sfi approved so wont warp or shatter than this built up t56 that can take 650lbs of torque
http://www.ddperformance.com/GM%20T56.htm
Old Dec 20, 2004 | 08:33 PM
chevcd2002's Avatar
Thanks for the replies. As far as the 700r4 ,no it is not a stock rebuild it was rebuilt by hughes transmission to be reliable as long as power was kept under 800ft/lbs. Yes I do run slicks 10.5 inch tire. As far as the ddperformance link goes your talking 500 to 600 more dollars than the mustang guys. I gather from the posts you dont like the tremec 5 speed idea.
Old Dec 20, 2004 | 08:38 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
lt1 flywheel/clutch options are alot stronger out there than t5...not to mention t5's are weak unless you get the new 600 or 500 tko's
formula1lle
Jan 29, 2016 10:56 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
