Well.. i think its my transmount???700r4
Old Dec 24, 2004 | 01:10 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
well anyway when i'm at a light or sumtin and just get the gas a nice tap say 1/4 throttle then get off cause the car infront of be wont go.. i get a BANG!!!! like i jacked the trans up then slammed it down.. im like WTF... so today i just jacked up the car.. looked at the mount.. and it don't look like anything is broken. I'm clueless..
Old Dec 24, 2004 | 01:17 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Put a pry bar in there and see if u can move the trans up and down between it and the mount
later
Jeremy
Old Dec 24, 2004 | 01:18 PM
Car: 2002 SS
Engine: Ls1
kk hold on
Old Dec 24, 2004 | 01:41 PM
Car: 2002 SS
Engine: Ls1
i took a bar did what u said.. trans mount is holding up... everything feels stiff the only part that is moving up is where that big rubber bushing is...it seems fine to me
Old Dec 24, 2004 | 02:52 PM
Car: 2002 SS
Engine: Ls1
Hey as u can see in the pic.. right below the trans that rubber mount looking thing looks pretty toasted... theres not supposed to be any play in it is there? cause its liften up a bit right there.. here i circled it in the pic... where can i get this mount
Old Dec 24, 2004 | 02:55 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
thaa "big rubber thing" is the trans mount as people reffer to it you can get it at any auto parts store forun around $8 but i would highly reccommend spend the $25? i think to get the energy suspension poly trans mount i broke 4 stock trans mounts in my 89 rs in one month put int and after market and didnt have a singleproblem they had them on the shelf at auto zone
Kevin
Old Dec 24, 2004 | 02:59 PM
Car: 2002 SS
Engine: Ls1
theres this one at summit
Bushing, Secondary Transmission Cross Member Mount, Chevy 1982-92 Camaro, Black
Monday $17.95
but you think autozone carries it? letme call them real quick
Old Dec 24, 2004 | 03:19 PM
Car: 2002 SS
Engine: Ls1
welp .. autozone dont carry it
Old Dec 24, 2004 | 05:20 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you have to go in and look on the shelf. ... it's on the floor where you walk around and look at stuff (it is where they keep the endlinks and stuff) just go down all the rows you will find it.
the idiots that work there no nothing!!! more than half the time I look up my own parts
Old Dec 24, 2004 | 05:44 PM
Car: 2002 SS
Engine: Ls1
lol
Old Dec 24, 2004 | 06:05 PM
Car: 87 Formula
Engine: 350 tpi
Exactly haha im pretty sure they should since the one by me has it and since there a chain they should all have the same stock if nto pick up that one from summti as long as its the polyurethane mount not the rubber one
Old Dec 24, 2004 | 10:36 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I got mine at Autozone too.
Old Dec 25, 2004 | 07:56 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
there are two trans mounts, the secondary one will not work since that I beleive is for a 2 piece crossmember from the earlier cars.
this is teh one you need,
355-3-1108G
http://www.jegs.com/cgi-bin/ncommerc...80&prmenbr=361
You may need to make the hole in the crossmember a little bigger to fit the bolt that comes with the mount. Do not use any bolt that fits in your crossmember hole otherwise it will strip the mount, use the bolt that comes with the mount and enlargen the hole if needed..
I ended up stripping out my mount since I didn't want to drill it at the time.
Old Dec 25, 2004 | 09:14 PM
Car: 2002 SS
Engine: Ls1
oh hmm .. no one else told me this...
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
