700r4 and lockup
Old Dec 28, 2004 | 11:55 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
700r4 and lockup
I just changed the 700r4 out and installed a stock lockup torque converter. I have all the lockup setting factory but have a question.
When it's in third and about 38mph it locks up, then it goes into overdrive and comes out of lock up then lockups again.
Makes it feel like it's a 6 speed. 1,2,3,LU,OD,LU again.
Lockup is programmed as factory, 38LU, 36UL in both 'Low gears' and 'Not low gears'.
The 4th gear switch is also programmed as factory which is '4th Gear N.O.' Not checked.
Any suggestions?
Old Dec 29, 2004 | 11:17 PM
Pro Built Automatics's Avatar
(When it's in third and about 38mph it locks up, then it goes into overdrive and comes out of lock up then lockups again.)
This is normal for some units.
Old Dec 31, 2004 | 11:25 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Originally posted by Pro Built Automatics
[BThis is normal for some units. [/B]
Well I'll be darned. And I thought something was wrong with it. I might raise the OD mph a bit. It's about 42 now and that's where I cruise on most streets around here.
Thanks for the response!
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
