10-bolt swap? 84 vs 94
I presently have an 84 3:08 non posi//drum brakes. I have access to a 94 Z-28 posi with a 3:73//disc brakes. Can I interchange this rear ends with out too much mids? Are the third members interchangable?
james
james
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
do a search or check out the tech. articles. for the best info and instructions on how to do a swap, the 94 will be stronger, but not by too much, it has 28 spline axles, instead of your 26, and the tires/wheels will stick out about 2" on either side
Hello, Michael
Aug 20, 2015 03:19 PM
