changing output shaft on th350
Car: 88 Camaro
Engine: 406
Transmission: th350
i searched and searched but never found a good answer so here goes..
i just bought (http://www.bulkpart.com/Merchant2/me...y_Code=Teckpak ) this kit so i could put a th350 into my car my question is how do i change the output shaft? thanks!
-jim
-jim
looks to me like a waste of money. what you should do is start with a long TS 350 or change the DS length and you wouldn't need that kit or the extra time, expense, and effort it requires. you will still need the B&M torque arm kit unless you have a floor mount aftermarket torque arm
Car: 88 Camaro
Engine: 406
Transmission: th350
obviously u didnt really look at the kit very well..i use the existing tailshaft off of my 700r4. so the torque arm mounts to its normal place..my speedo gears and sender are all correct can still use my drive sharft..it was recomended by quite a few people.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Originally posted by ede
yeah you're right that looks a lot easier and at a lot less cost than the b&m kit
it made me laugh anyway
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
