REMOVING TRANNY questions
Old Jan 7, 2005 | 09:50 AM
FORMULA75's Avatar
Car: 1984 FIREBIRD
Transmission: AUTOMATIC
I will be removing my tranny this weekend to see if there is a crack in flex plate.
Car has loud Knock/Rattle. After much trail and error it has been suggested that it may have a crack in flex plate.
What else should I check or change while I have tranny out.
Also are there any tips you may have that would help with removal or instalation.
Thanks in advance.
:hail:
Old Jan 7, 2005 | 09:59 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Rear main seal!! Now would be the perfect time. Good luck, a couple of those bolts are fun.lol Make sure you have a good asortment of extensions and flex sockets. Oh yeah, and air tools make life easier aswell!
Old Jan 7, 2005 | 11:09 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
A tranny jack is nice too. You can get them for $75 at the autoparts stores.
Old Jan 7, 2005 | 06:00 PM
ede's Avatar
ede
9/16 flex socket, 36" extension, impact wrench, trans jack, fly wheel turning tool will all make life easier for you
Old Jan 7, 2005 | 10:19 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
check to make sure the torqe converter bolts to flexplate are tight...mine came loose i just tigened it down and it was fine... yes youll also need a swivel and 21-23inches in extension to get to the top 2 bolts for the bell housing...and drain the fluid first...otherwise youll hvae 8.5quarts of tranny fluid on your garage floor
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
