what else is involved in auto to 5 speed swap...
Old Jan 11, 2005 | 10:58 AM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey guys ive got everything minus a clutch and fly wheel to do a 5 speed swap in my car.... any way i own an 86 irc with a tpi lb9 (305) in it that is presintly auto matic.... any way do i have to change the computer chip to a standard one of the same year car or will i get buy with the stock chip???
also i have put aoutos in auto cars before like mine but i have never done this before.... i know there is a small article on the web site on how to do the 5 speed swap but is there anything else involved...
Old Jan 11, 2005 | 11:39 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You can get a chip from a manual car and it will work fine. You can also have someone just burn the bin onto a new chip for you. If you know someone of course.
What is your rear end gear size? 2.73, 3.42 , etc. Post it up and I will get the right bin for you.
Old Jan 11, 2005 | 11:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
torque arm bracketry is different, but the rubber mount itself is the same.
On my v6, the trans cross member is different I belive (not 100% sure).
shifter plate, shifter, hydro lines, peddles, ecm/prom, rear gears(maybe, not all), flywheel, bellhousing, tranny, some wiring.
Old Jan 11, 2005 | 06:18 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
You dont really need to change the chip. I didnt on mine, which is the same as yours. All I did is reset the minimum idle air and it runs awsome. The flywheel is much lighter than turning the auto (torque converter, pump, ect.)so the idle will go up.
Old Jan 12, 2005 | 11:22 AM
z28monster's Avatar
Car: 86 IROC-Z
right now i am not going to change the chip i am just going to try to make the idle be lower like said how to before..... any way im pretty sure i have everything to do this and i just bought a brand new clutch kit for it today o just have to go pick it up in a few....
also my tranny has "borg warner" on it.... is this a good tranny to have?
i still need to find a fly wheel for my swap though... does any one know ware a good place is to find one online... through GM they want like 300 bux.... ware can i find one used or after market for cheaper....
also if any one could post some pics of all the pieces needed for this swap i want to make sure i have everything to do it... or other wise i will post a pic or two of the parts i got for the swap.... because i wasnt the one who took the swap parts out of the donar car....
any way so i can use my stock auto chip and get away with it.... how exactly do i go about lowering the idle after the swap to make it a good driver being it will be idleing much higher then needed after this....
also i have a posi 3.23 rear with disc breaks so it looks like ill get by with my rear end.... or do you guys think other wise about this.... should i think about 3.73s ?
any way also i was under the asumption that drive line wise i would get away with everything.... whats with the torque arm hook up... is there something that i am not aware of that i will need or will the T5 mate up to my drive shaft and torque arm well enouph....
also again i have a "borge warner T5 "is this a good one to have it looks to be in very very good shape and i have a brand new clutch in the box still for it...
please help me out guys i realy realy hate automatics and want this to work out for me...
also you auto guys that swiched to T5 how did you like it.... what are the pros and cons of doing this to my car.....
Old Jan 12, 2005 | 11:58 AM
Dale's Avatar
Engine: 350 S-TPI
borg warner is the brand that gm used, so you basically have a gm transmission.
On the left side of the tranny, near the tail. Their is a mount where the torque arm slips into. You need that bracket system for a manual. Your auto has one, but its different. Driveshafts slines from 85 to 2002 are same auto or manual.
Cross member, someone said the v6 vs v8 system is different, so your current cross member may work.
try searching on car-part.com for a flywheel, call the yards, do not email. I have so far had great luck off that site.
OO, their is a bracket that goes to the cat-converter, it is different on auto vs manual, it mounts up on the right side tailshaft of the tranny.
Old Jan 12, 2005 | 12:56 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
I like it alot better than the auto. the only problem with my clutch system is something always acting up causeing the clutch not to disengae. but other than that i love it. my gas mileage went up a little bit preformance went up a little. all around i don't really have a complaint with it. good luck with the swap.
Old Jan 12, 2005 | 10:31 PM
z28monster's Avatar
Car: 86 IROC-Z
yeah the car and everything is at a friends garage ... so ill have to go check it out tomorow but i think that i have the tail shaft on the tranny also.... so i should be set there.... and i have hers that the v8 auto cros member is the same... but it doesnt matter cause i got the T5 cross member with the stuff i got.. lol so im set there also...
Old Jan 13, 2005 | 12:19 AM
z28monster's Avatar
Car: 86 IROC-Z
also guys i still need to buy a fly wheel for the swap... being my car engine is an 86 lb9 then what fly wheel do i get.... one for an 86 right? how many teeth and all that...
i have been looking around and they are way out ragesly priced compared to an auto fly wheel most places want like 250-300 bux for one.... is there any place i can find one used or something like that or after market that is cheaper then that....
Old Jan 13, 2005 | 09:13 AM
damn thats high. mine only cost about 150. and that was before my discount. try summit or jegs i don't know what the prices are but it they will give a good estimate on aftermarket flywheels.
Old Jan 13, 2005 | 12:47 PM
z28monster's Avatar
Car: 86 IROC-Z
ware did you buy your fly wheel....
Old Jan 13, 2005 | 03:58 PM
i bought mine from advance auto when i was still an employee there. it is just a stock one though. it took me a while to find the correct one becasue there access to flywheels is limited for some reason. I will see if i can come up with a number or some more info for you.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
