3:55 gears?
Car: 1990 Camaro RS
Engine: 90 Caprice 5.7
Transmission: 700R4 Auto
3:55 gears?
I found a full axle for sale with 355 gears. Is this posi? And if so, is it a good rear, should I buy it? I have the stock RS non posi rear whatever that may be right now.
gear ratio doesn't have anything to do with what kind of carrier it may have, or not have. it seems you're a bit confused about terms, an axle is a shaft that connects the carreir to the wheel. the easiest thing to do would be to look at it and see if it's a posi or not. might help too if you said what you have or what sort of rear you're looking at.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
3.55 ? what is the axle from ? what model is it ? sounds like an old 10 or 12 bolt from a chevelle or something similar, they commonly were 3.55 late 60s early 70s
pull the diff cover to make sure of whats in it, for all you know it may be broken, who knows
never buy an axle without opening it up and closely inspecting, same with transmissions, and evne engines whenever possible
good luck
good luck
Engine: 4.3L Z TBI
ok
i dont know on that one, ive only been inside of one 8.8 and it was under an 82 ford f150 pickup, it chucked the gears, so we put an old 9" under it
Car: 4
Engine: 6
Transmission: 5
I don't believe that ratio (39:11) exists in a 7½" 10-bolt.
It's pretty common in some other rears; Chrysler 9¼" for example, or the "classic" rears.
Ratio has nothing to do with whether it has a posi carrier or not.
Engine: 4.3L Z TBI
after much thinkign and finally remembering, its the 3.50 ratio thats commmonly found in the old 9" axles, 70s older
other than 4.10 or so under the old F-100 pickups
i need to get a couple more soon, one needs to go under my 84 c-10 so i can rid of the crap 8.5" and 2.73
i could have it all welded in place in about an hour or so afte ri go get new leaf spring perch mounts for the axle tubes they are inexpensive
thanks
thanks
Car: 1990 Camaro RS
Re: 3:55 gears?
Im glad you all are as clueless as I am. I had never heard of the ratio in concern to Fbodies, the women at the junkyard told me that this rear was being pulled off of a 1992 camaro RS, thats why I assumed it was a stock rear. Could she have possibly been mistaken with 3.42?
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
if its the stock rear, 2.73 auto, 3.08 manual. the only way to be sure is to count the teeth and do the math, dont pay for anything until they pull the cover for you.
41-15 2.73
40-13 3.08
42-13 3.23
41-12 3.42
41-11 3.73
41-10 4.11
41-9 4.56
41-15 2.73
40-13 3.08
42-13 3.23
41-12 3.42
41-11 3.73
41-10 4.11
41-9 4.56
Car: 4
Engine: 6
Transmission: 5
If it's a 6-cyl, it may have a better ratio. Some of the 6-cyl 5-speed those came with 3.42s.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
