Ripper knob
Old Jan 13, 2005 | 10:30 PM
88fbird's Avatar
Car: 84 S-10:(
Ripper ****
I have a B&M ripper. I got it used, so of course it didn't have a ****. What I need to know is where can I get a **** for this thing? What is the thread size? I tried the universal *****, but the threads are too small. I can't even get it on the shifter without the inserts. The shaft looks like it is at least 1/2" in dia.
FBird
Old Jan 13, 2005 | 10:40 PM
12secformula's Avatar
Car: 94 Z-28
B+M sells ***** specifically for our shifters. So do others. it is the same size as the stock shifter. I think if you do a search you will be able to find the size, then go from there.
Old Jan 13, 2005 | 11:18 PM
rjmcgee's Avatar
Mine has some cheesey plastic reducer that threads into the **** and then that threads onto the stick. Not great quality but maybe something you can find at an autoparts store.
Old Jan 14, 2005 | 05:15 AM
88fbird's Avatar
Car: 84 S-10:(
My stick **** had no threads. It just slid on the stick. I have a B&M handle that won't thread on. I haven't found a B&M **** that will fit because I don't know what size the threads are. I just want to make sure I get one that will fit.
Old Jan 14, 2005 | 06:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Humm, the stock **** on my Camaro fit fine.
JamesC
Old Jan 14, 2005 | 07:57 AM
Car: 94 Z-28
As far as I know the threads on the B+M are the same as stock. I believe it is 16mm x 1.5. I hope this helps. Also that is the of the T56 ***** also so if you find some of those they should work.
Old Jan 14, 2005 | 03:36 PM
88fbird's Avatar
Car: 84 S-10:(
That helps. My stock **** was attached to a sleeve that slid over the shifter. I haven't seen it for about 3 years though. So, I don't know if it was screwed onto the sleeve of if it was part of the ****. When I modified my stock shifter, I used the B&M t-handle. So, when I got the ripper the stock one was long gone. At least I'll be able to find something now. Thanks
FBird
Old Jan 14, 2005 | 04:33 PM
Car: 94 Z-28
No problem, I'm glad to help.....when I can.
Night rider327
Feb 25, 2016 09:50 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
J. Chris Davis
Sep 28, 2015 11:55 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
armybyrd
Sep 16, 2015 07:00 AM
