Should I Change 3.27 to 3.73
Old Jan 18, 2005 | 09:33 PM
89GTA2LV's Avatar
Car: 89 Trans AM GTA
Engine: 5.7L
I have an 89 350 TPI with the 700r4 overdrive transmission. I also have the 9 bolt rear with 3.27 gears.
If I install the 3.73 gears what should I expect? Good or bad?
Old Jan 18, 2005 | 09:52 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I'm a non-computer guy, so with the disclaimer that"I don't know how it will effect the computer" I would say yes, absolutely. Generally speaking the most bang for the buck in getting a car to accelerate is by changing the rearend gearing. (just like , generelly, the biggest bang for the buck to increase engine output is a set of headers). I have been running 4.11's in my 83 L69 and they're a little steep, so I went back to the 3.73's. They're a real good all around ratio IMO. I would also recomend these guys:
http://www.reiderracing.com/
I have had nothing but good results from them, BTW, if you're gonna pull the rearend apart, you might as well put a posi in it, or you'll be sorry later.
Here's what a 4.11 sounds like (using 1st and second gear in the vid)http://www.fl-thirdgen.org/blacksheep-1/camaro.mov
hectre13
Dec 11, 2023 08:14 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
BAMiller
Sep 14, 2015 06:38 PM
89fast5oh
Aug 24, 2015 08:14 AM
