Can Lakewood Coil Spring Traction Bars eliminate the need for a torque arm?
Old Jan 20, 2005 | 09:15 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I am thinking of buying a bolt-in 9" ford rear. I has everything except for the torque arm bracket. The guy tells me that with Lakewood Coil Spring Traction Bars that you won't need a torque arm. Also, he says that you can set pinion angle with these. Is this gonna work? I'm thinking no but had I known about these I wouldn't have bought the whole Spohn adjustable torque arm and relocation brackets.
Attached Thumbnails Can Lakewood Coil Spring Traction Bars eliminate the need for a torque arm?-lift-bars.jpg
Old Jan 21, 2005 | 07:51 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
NOT SURE ABOUT THE LAKEWOOD ARMS? BUT I WAS DOIGN SOME CHECKING AND FOUDN THAT MOSER MAKES A TORQUE ARM BRACKET FOR 9 INCH PART NUMBER 7230.....CALL THERE TECH LINE, SHOULD BE ABLE TO ANSWER ANY QUESTIONS... HOPE THIS HELPS...
Old Jan 21, 2005 | 01:35 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I actually bought a set of Lakewood LCA's last night, but i purchased the normal ones..
I was looking at those, but it does look as if you can change pinion angle with those...but i am not positive.
Old Jan 21, 2005 | 06:06 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Thanks for the part number. I went to www.moserengineering.com and did not find it so I tried to call and they had already closed. It was after 5:00 eastern time. I'll have to wait until Monday.
Old Jan 21, 2005 | 07:22 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I dont see how that item could replace the tq arm.
Old Jan 21, 2005 | 07:32 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
I WAS ACTUALLY LOOKING AT A 12 BOLT ON EBAY THAT DIDNT HAVE A TORQUE BAR MOUNT...I EMAILED THE SELLER AND HE GAVE ME THE MOSER PART NUMBER....I CALLED MOSER AND THEY SAID THAT THAT PART NUMBER WAS FOR A 9 INCH FORD TORQUE ARM MOUNT FOR THERE REAR END....
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
