Shattered t5 bellhousing
Old Jan 22, 2005 | 02:28 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I went to the shop today and started redoing my exhaust and noticed that my bellhousing isnt just cracked, its more like shattered, half of it must be the only thing holding it htere as there is an enormous crack running half the circumference and another crack mid way intersecting that crack and going a different direction.
Anyone ever had this happen to them?
Im still wondering how the hell this happened, ive never heard of this happening to anyone short of truck people.
The car only does mid 13s, has a stock clutch, non WC t5, and drag radials
Old Jan 22, 2005 | 08:52 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
yep, cast aluminum bell, rough cast at that. can't take the stress with drag radials, you've run that car quick for quite some time now, probably just couldn't take the pressure anymore.
Old Jan 22, 2005 | 10:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Poly or solid trans mount with rubber (old/worn?) engine mounts? Trans won't rotate from the stiff mount while the enigne moves all over.
RBob.
Old Jan 22, 2005 | 11:05 AM
TexasLT1's Avatar
Car: '92 RS
I'm running a T-5 behind an LT4 with poly trans/motor mounts and drag radials out back, with 12.8's the norm now, and I've never damaged the case of the trans or anything, only internal parts. Power alone shouldn't do anything to the bellhousing.
Old Jan 22, 2005 | 03:55 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I have a lakewood blow proof that I would give up..Pm me if U want it
Old Jan 22, 2005 | 08:26 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
You might be onto something RBob, its not poly but its like solid rubber. Came out of the junkyard when i got the tranny to begin with. Have never seen one like it, just a solid brick of rubber.
The motor mounts are factory originals.
I suppose it could also be that this is an 83 bellhousing.
anyways thanks for the tips.
I may look into that lakewood you got greeze monkey PM me with how much you want for it
Old Jan 22, 2005 | 09:25 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i had never pulled a trans until i did mine, i was very surprised how flimsy the stock bellhousing was. kind of scary it and some sheet metal is whats there to protect your legs.
greezemonkey, if Pablo doesnt want the scatter shield, i do
AUS-IROC
Oct 24, 2009 06:04 PM
tyson__91
Dec 3, 2003 07:00 PM
